Group: DynoMotion Message: 12863 From: Moray Cuthill Date: 2/25/2016
Subject: Message box to get value?
I'm probably missing an obvious example, but how to do you get KFlop to display a message box in KMotionCNC asking for a value?
I'm working on my turret recovery program, and I'm wanting to ask the operator for a position to attempt to change to, then use that value within the KFlop program.
Also, are there any examples for setting tool offsets by taking a test cut then entering the actual value?
My final major job before getting my lathe fully working on KMotionCNC is some way of setting the tool offsets easier. I'll admit I've not had a chance to look at any of the offset functionality in much detail, but was wondering if there are any examples to get an idea of the process involved.
Moray
Group: DynoMotion Message: 12864 From: Tom Kerekes Date: 2/25/2016
Subject: Re: Message box to get value?
Hi Moray,
See the example MessageInputBox.c
When referring to tool offsets do you mean length?  I suppose not as you have a lathe.
Moray
Group: DynoMotion Message: 12865 From: Moray Cuthill Date: 2/25/2016
I knew I'd seen an example somewhere. That'll tech me for not looking past the MessageBox examples.
I've always classed them tool offsets on the lathe, but you could class them as tool lengths.
What I'd like to implement is something vaguely similar to the tool setup in Mach 3 turn.
The basic process I have in mind is -
Jog to a suitable point
Take a test cut.
Measure the test cut
Enter the actual size into a pop-up box
Offset is then calculated and stored into the tool table
Mach3 does it by entering the value into a DRO, and then using a Touch X/Z button to set the current tool position and update the tool table.
The critical axis is the X.
I normally just rely on visually touching of the Z, but a similar technique and entering 0 for the actual size will work.
Moray
On Thu, Feb 25, 2016 at 9:26 PM, Tom Kerekes tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi Moray,
Moray
Group: DynoMotion Message: 12866 From: Tom Kerekes Date: 2/25/2016
Moray,
I think you'd have to code something along the lines:
#1 Read the X DRO
#2 Ask Operator what it should be
#3 Compute a correction (ie difference)
#4 GetToolOffsetX
#5 Adjust it
#6 SetToolOffsetX
See the ToolTableSet.c example
Take a test cut.
Moray
Hi Moray,
Moray
Group: DynoMotion Message: 12881 From: Moray Cuthill Date: 2/27/2016
So I've done a bit reading up on tool offsets, and from previous posts I've gathered the following points-
Within G-code any number below 100 is assumed to be a slot ID, with 100&above a tool ID.
The M6 command within KMotionCNC transfers the Slot ID in the chosen VAR and the tool ID in VAR+1 (which in my case I'm using 7, so Slot is in 7, and ID in 8).
Would it be correct to assume that all tool table values are in imperial/inches?
And given I run in metric, I'll have to convert values before storing them in the table?
I'm wanting to make sure I understand the basics before I start work on the on any code.
Moray
On Thu, Feb 25, 2016 at 10:21 PM, Tom Kerekes tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Moray,
#1 Read the X DRO
#4 GetToolOffsetX
#5 Adjust it
#6 SetToolOffsetX
Take a test cut.
Moray
Hi Moray,
Moray
Group: DynoMotion Message: 12883 From: Tom Kerekes Date: 2/27/2016
Hi Moray,
Yes tool numbers 100 and greater are assumed to be IDs.  I would think you could just use the specified Slot number regardless.
No.  Tool table values and fixture offsets are just unit less numeric values.  They are assumed to be in the same units as the context they are being used.  You can request the current units that the Interpreter is in as shown in the example by calling:
    GetMiscSettings(&Units, &TWORD, &HWORD, &DWORD);
Moray
Moray,
#1 Read the X DRO
#4 GetToolOffsetX
#5 Adjust it
#6 SetToolOffsetX
Take a test cut.
Moray
Hi Moray,
Moray
Group: DynoMotion Message: 12885 From: Moray Cuthill Date: 2/27/2016
My plan was to use 100 and upwards in g-code, as that way I don't need to continually swap Slot numbers in the tool table when I change tools. The same tools usually go in the same slots, so all I need to do is swap tools and adjust the necessary offsets (typically just length for drills, as the turning tools rarely get changed). Would this work?
So if the offset values are unitless, what happens if I was to set everything up in metric/mm, then load an imperial/inches (G20) g-code file?
I always work in metric, but I'm curious as to what would happen in regards to tool offsets.
Moray
On Sat, Feb 27, 2016 at 9:11 PM, Tom Kerekes tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi Moray,
Moray
Moray,
#1 Read the X DRO
#4 GetToolOffsetX
#5 Adjust it
#6 SetToolOffsetX
Take a test cut.
Moray
Hi Moray,
Moray
Group: DynoMotion Message: 12886 From: Tom Kerekes Date: 2/27/2016
Hi Moray,
Yes I believe that should work.  Its best to use Tool IDs in the Gcode.  The Tool Table maps the IDs to whatever slot they are in.  If they always load to the same slot then no changes are ever needed.  If you decide to load the tool to a different slot then update the Tool Table to which slot the tool is in.
The fixture and tool offset tables are not set up for mixing units.  The units in the table are assumed to be the units of the job that uses them.  If you put mm numbers into the tool table and then use those with GCode in inches the result will be wrong.
Moray
Hi Moray,
Moray
Moray,
#1 Read the X DRO
#4 GetToolOffsetX
#5 Adjust it
#6 SetToolOffsetX
Take a test cut.
Moray
Hi Moray,
Moray
